twouvakind
Site Donor 2025
I too think Kano has changed hands, I remember something about no more mail order retail. I do like their Floway.
I've always had really good results with CRC Freeze off. My cousin was out visiting a few years ago. A few of the bolts on the underside of his Nissan 350z wouldn't turn. When you spray it, it bubbles like it's wicking into the bolts.Over the past few years Kroil does not seem to be cutting it so my latest ongoing project a full bushing replacement on the rear of an old Subaru, the body is rust free but holy god the suspension parts are very badly rotted, no bolt came out without going to war with it. Perfect time to try Kroil, Gibbs and FreeAll just for fun, if it does not do much smoke wrench and cutoff wheel time.
I chose bolts that were close together and impossible to remove with anything but hand tools (to tight even for the angle head impact) and sprayed one with each product in multiple locations. Nothing scientific here just my own observations. The Kroil surprisingly was a miserable failure, the free all wasn't much better but stunk the high heaven, that stinky crap (it smells worse than the new liquid wrench) went in the bin.
The Gibbs did a remarkable job with no objectionable odor, I got everything loose after leaving all 3 product overnight. It stayed wet the longest and you could see the rust dripping off. Impressive.
https://www.amazon.com/Gibbs-Brand-Lubricant-2-12oz-cans/dp/B00AFJXIJQ
How long did you leave the Kroil to soak the part?Over the past few years Kroil does not seem to be cutting it so my latest ongoing project a full bushing replacement on the rear of an old Subaru, the body is rust free but holy god the suspension parts are very badly rotted, no bolt came out without going to war with it. Perfect time to try Kroil, Gibbs and FreeAll just for fun, if it does not do much smoke wrench and cutoff wheel time.
I refuse to use PB Blaster anymore! The last 5 cans I bought ran out of propellent too soon leaving half the can unusable and the smell is terrible. Oddly enought the supertech basic "lubricant" in the gray spray can works pretty darn good even though freeing bolt isn't it's design intent.
PB Blaster smells nasty! The one and only can I ever bought went into the trash pretty quick. I got it on my coveralls and it took quite a few wash cycles before that awful smell was gone.I refuse to use PB Blaster anymore! The last 5 cans I bought ran out of propellent too soon leaving half the can unusable and the smell is terrible.
I agree! Although I haven't come up with an alternative product yet(other than KROYL), I did write B'Laster about 2 yrs ago to tell them about this lack of propellent issue and how many years I've been using their product as a DIYer and at the company(s) that I worked for. In total I've used their B'Laster product(s) for ~50 years at some point and found this unacceptable and won't buy it any longer...which I haven't. They did not respond.I refuse to use PB Blaster anymore! The last 5 cans I bought ran out of propellent too soon leaving half the can unusable and the smell is terrible. Oddly enought the supertech basic "lubricant" in the gray spray can works pretty darn good even though freeing bolt isn't it's design intent.
I left all of them overnight probably around 16 hrs.How long did you leave the Kroil to soak the part?
Forum name is appropriate name.PB Blaster smells nasty! The one and only can I ever bought went into the trash pretty quick. I got it on my coveralls and it took quite a few wash cycles before that awful smell was gone.
I found that too. I occasionally get some DI injectors that are so carboned up on the tips it makes it hard for the ultrasonics to get into the injector.I bought some Gibbs oil when Trav first posted this and yesterday I finally used it to clean my filthy Ruger 22/45. It removed the carbon and dirt almost instantly and softened the build up to the point where a few tooth brush strokes wiped them away and the Gibbs left a nice protective oil film. Thank you Trav.
