the install instruction for block heater (Acura TSX) says drain coolant first from rad and drain plug (on engine jacket) and then install the block heater on drain plug hole. trying to cut it short, and save some coolant, can i just open the rad cap to release pressure and remove the drain plug and quickly install the block heater, instead of draining? or if there is any other trick i would like to learn!! thanks!!
