My daily driver is a 1973 Chevy truck with a 350, it's pretty cold blooded. I don't drive that far and it rarely gets a chance to get "hot". I also have to step on the throttle to start it cold, but not after it's warmed up. I get terrible gas mileage.
I was thinking about installing a block heater, even though the temps rarely get below freezing here. Something that would warm the engine to maybe 120 degrees before starting. This way I should save gas on cold starts and let it run a little warmer on my short trips.
Question is, what type of heater should I use and how many watts? I don't think I want to try and install the freeze plug type with the engine still in the vehicle. Then there are heaters that go in the lower radiator hose, and others that plumb into the heater hoses with a small circulation tank. And then there are the heat pad type of things that stick to the oil pan.
I was thinking about installing a 2000 watt circulating tank type that plugs into the heater hoses. This way I shouldn't have to plug it in for very long before starting. What do you guys think? Is that too much heat to be using when it's not freezing outside? Should I also think about some type of oil heater, or will a coolant heater adequately heat the oil too?
