Treadwright retread failure <500 miles. Thoughts?
Kentucky
Happy Halloween everyone! I sure got my scare this evening when I had one of my brand new (can't really call it that!) Treadwright retreads come apart on me on the highway doing 70mph. My trip into town where I work is about 35 miles-- the only reason I took the truck this morning (try to avoid it, as it gets 10mpg) was so I could get the alignment checked; I always do that after a new tire install. The old ones (Michelin LTX AT/2) wore nice and even. Alignment checked out okay, though they noted I should replace the outer tie rod ends soon (strange, because I just replaced them 8 months ago). Truck is sound mechanically, suspension is good. Truck is an '85 Ford F-250. Tires are LT265/70/17 Load Range E. Passenger rear was the one that failed.
On the way home in fairly dense traffic doing 70, all the sudden there was a loud BOOM, the whole truck shook, and a look in the rearview revealed black debris of some kind shooting out of the back of my truck. Cars were trying to avoid it, and it's a miracle it didn't cause an accident. My first thought was my cheap plastic toolbox got whipped in the wind and blew out, but I spotted it in the bed a couple minutes later. Mind you, I'm still doing 70 and truck is driving fine, so tires weren't my first suspicion. However, after a moment of pondering, I realized that whatever impact/collision/etc. had occurred was too violent to ignore. It felt like a Moose had run into the side of the truck. I pulled over on a side road and spotted what you see in the images below.
Is this a fluke, or somewhat common on retreads? I'm real hesitant to drive the truck now, even if this bad tire were to be replaced. I bought these because they had a lot of good reviews (few bad, but I chalked it up to idiots not inflating their tires right, beating on them etc.) I grew up with my parents buying retreaded studded snow tires for winter season on all our cars in Northern Vermont. They never had any issues, so I thought this to be safe bet. Now I'm second guessing my decision. I can't afford another $800 set of tires until next year; luckily this truck is used only for bad winter weather and recreation/camping in the summertime. Maybe coincidence, but this tire that failed was the one that balanced the poorest. It needed about 12 ounces of weight, but the guy at Costco thought that was okay for a retread. The others are 4oz or below. Thoughts?
Not safe to buy a re-tread when the tire casing isn't intended for re-treading.
It's not the same as losing a tire on an 18-wheeler. You lose a corner on a passenger vehicle and you can die.
Warranty the tire if you can, and then sell the set on craigslist to someone who will put them on a farm truck.
Ouch! I considered buying these one time, but then read that they had no speed rating, so I passed.
Will probably drive through the winter on them, and might do just that. The odd thing is, there's so many good reviews. My neighbor bought a RAM 1500 (98-2002) with these same exact tires a couple years ago (he probably doesn't know it, as it has a Toyo sidewall, but is clearly a retread given the same BFG A/T tread pattern as mine) and he's still driving on them and they look great. Mine is one of the new bead to bead re-molds, that has the Treadwright branding on the sidewall.
I almost bought a set of these but could not justify the risk to save a couple hundred bucks. Now with the hassle and remounting, etc. The savings is gone. Get a real BFG A/T and never worry about it. Now every time you drive with these tires you will be nervous. Not worth it.
In Kansas you can get them on cars and trucks but CDL is a no go. Personally I would avoid them at all costs because of what ive been told about them growing up.
I'm glad you're OK and not hurt! It's never ever a good idea to buy a retread for a passenger car or truck. Been working in the trucking industry for almost 20 years and we see a lot of retread tires and a lot of them fail. I would never allow a retread tire on my family's personal vehicles after what I've seen working around tires for the last 20 years. Honestly I'm surprised they haven't been outlawed across all industries.
Looks like you should have just bought another set of LTX's.......
Hindsight is 20-20!
I have wondered about those tires. Saw mention of them plenty over the years. I had four blowouts with retreads in two days a few years back. They had just been installed on the rear duals of my company owned work truck.
- Can you still buy retreads for cars? I remember buying a set of 185/70R14 retreads for an old K-car I had when I was 16. None of the tires matched and it looked ridiculous.
Unlike OTR and Airplane tires, passenger and light truck tires are not designed to be retreaded. I've seen quite a few Treadwright failures. They take an old, abused, deteriorated, likely patched mystery casing, and vulcanize some new rubber onto that mystery casing.
IMO they are false economy. I might run a set if there were no alternative, and the vehicle never ran down the road at highway speed. I'd take the cheapest new Chinese tire over a mystery Treadwright retread.
I have treadwrights on my jeep for 2 years no issues. The few times ppl have had issues with them, just call treadwright they will take care of you.
One of my tires got lost im shipping 2 yrs ago and they overnighed one too me.
Glad your safe
Originally Posted By: 92saturnsl2
Thoughts?
Not only could you have injured yourself, but you could have injured or killed someone else.
Think about all of the tread casings you see laying along side the interstate. Those are from semi trailer tires that are retreaded. Imagine how poor the quality is on a regular vehicle tire that isn't designed to have a new tread super glued on.
Can you afford it when the next chunk of tread flies off and hits another vehicle? Can you afford it when a chunk of the tread flies off a front tire and puts you in the ditch, or worse yet causes a collision?
There are a lot of things that aren't covered under warranty. Broken tread belt causing casing failure, radial split causing casing failure, belt separation, etc. So not only do you have a set of tires prone to failure, the warranty is extremely limited to the materials of the remolding process only.
There are a few places to never cut corners-tires is one of them. Consider yourself lucky that you didn't kill someone, and use it as a lesson to invest in decent quality tires.
Retreads?
Really?
I didn't know you could still get them.
I say yes, by all means use them, if it saves a few bucks.
What the [censored], (really? I can't say h-e-l-l ?) maybe you could find some tires in the garbage and save even more.
And also, use ditchwater instead of anti-freeze.
Geez, I spent over $900 on my most recent set of Michelin LTX's.
Is nearly a grand a lot to spend on tires for a truck?
Yes.
But I get over 80K miles from them, and I don't worry about them coming apart on the highway, or anywhere else for that matter.
