Stolen from an article:Surprised social media is still available there.
I used windshield urethane on beakers cleaned with IPA and the assemblies cured for over 24 hours. I was contemplating roughing up the mating surfaces with a Dremel though. Maybe I could have researched a better epoxy for the application. I disconnected the fuel pump so the engine wouldn't run to keep the oil pressure low and cranked the starter for a few seconds at a time. I wasn't planning on running the filters for a long time anyway, just enough to get video of oil flow. I had the car jacked up on one side with multiple cameras recording.Did you wait 12-24 hours for the urethane to cure before trying the experiment? And did you use the primerless to glass kind?
Looks like you used the 3M urethane which requires a primer for maximum adhesion.I used windshield urethane on beakers cleaned with IPA and the assemblies cured for over 24 hours. I was contemplating roughing up the mating surfaces with a Dremel though. Maybe I could have researched a better epoxy for the application.
Only 17k views in 4 months which is pretty weak but I only have 4700 subscribers. Garage 54 has over 600k subs, with that kind of viewer base your videos gain traction fast.
Their video currently has 153k views which should have yielded them around $300-$400.
With186 Million total channel views, this could have earned them $457,000 maybe more maybe less.
That's 41,740,625 rubles! Certainly a lot of money is Russia.
Many Youtubers like Scotty Kilmer are making thousands of dollars a day. Payment depends on the niche. My estimation is Scotty is a multimillionaire from his channel. 1.8 Billion views = $4.4Million dollar lifetime earnings.
I can’t tell if Scotty’s videos are supposed to be humorous, or if he’s being serious. The dude is a total goon.
..but not getting paid anymoreSurprised social media is still available there.
Scotty is quirky for sure. Wonder how he choreographs his speech with those hyperactive hand movements. However he is a very good mechanic and a shrewd guy.The very few of his videos I've watched, I wondered if he was on crack or something.
That would have been helpful! I’m actually happy the last filter exploded due to the dramatic effect of the oil the lens and color change.Looks like you used the 3M urethane which requires a primer for maximum adhesion.
That’s just Scotty’s personality. Its what sells to the general public. I think he had a cable tv show about auto repair before YouTube.The very few of his videos I've watched, I wondered if he was on crack or something.
Scotty is the king of click bait titles and thumbnails! Apparently it’s working though. He can retire many times over.That may be, but between his mannerisms and the click-baity thumbnails he uses, I don't watch his videos.
