BrendanC
$100 site donor 2024
i have my 80e running through a trucool 40k and bypassed the radiator. 8600lb truck, 3200RPM triple disc runs about 150-175 in traffic
Absolutely do not do this. There is a lot of conjecture on forums that the radiator heats the fluid more often than it cools it, this is completely not true.I wonder if I should have completely bypassed the radiator I just put it and pair with the original
Absolutely do not do this. There is a lot of conjecture on forums that the radiator heats the fluid more often than it cools it, this is completely not true. Do not do which one completely bypass it or what do you mean do not do what
Don't do what completely bypass it or add do what I did and add one in pair with the originalAbsolutely do not do this. There is a lot of conjecture on forums that the radiator heats the fluid more often than it cools it, this is completely not true.
yes it may cool the fluid some but on my silverado removing the radiator dropped my temps from 200-220 to 150-170. i left the radiator in the loops of both accords when i added external coolers and they run around 170 instead of 220-250.Absolutely do not do this. There is a lot of conjecture on forums that the radiator heats the fluid more often than it cools it, this is completely not true.
So did you completely do away with radiator one or did you disconnect the external one to the radiator Outlet for the transmission fluid are they both still hooked upyes it may cool the fluid some but on my silverado removing the radiator dropped my temps from 200-220 to 150-170. i left the radiator in the loops of both accords when i added external coolers and they run around 170 instead of 220-250.
radiator is 100% eliminated on my silverado.So did you completely do away with radiator one or did you disconnect the external one to the radiator Outlet for the transmission fluid are they both still hooked up
From what I've been told the 4l60e don't have onelots of ford edge and flex transmissions where taken out by a simple 7$ faulty thermostat for the tranny oil cooler.
