I have a 2002 Explorer. This week I want to drop the transmission pan, change the filter, clean the pan, new gasket etc. and refill. I understand that you only actually change like 5 qts of fluid when doing this. So after that, I want to drive the car for a bit and then just undo the drain plug and then re-fill one more time. I figure after doing this, that it'll be 75% new.
Anyways, my big question is.... how long does a transmission take to circulate/mix all of it's fluid? Would just driving it around the neighborhood for like 15 minutes do the trick? Or should I drive it for an entire day, then drain the next day? Or, would just running it on the jack stands do the trick?
