Hey, I have a 2004 Jaguar XJ8 with almost 75,000 miles. It has the ZF 6speed auto with is " Sealed for Life ", whether thats true or not is debatable and isnt what Im looking for.
At 69k miles I did a complete fluid change using Castrol Multi-Import Vehicle ATF. I did extensive studies and Castrol backs it as replacement fluid for BMW LTxxx, which is Shell Msxxx rebranded( I forget the actual numbers) which is the fluid all ZF 6speeds use.
I did a few more flush and fills with a more recent one just a week or so ago. I have on order a new Pan that has the filter built in, what I need advice on is picking the replacement fluid (about 5qts maybe 6).
The Castrol is good, by good I mean it has comfortable upshifts but gives me a slight lurch coming to a halt. This ir most likely a software issue since a few TSB's have been issued to correct this from all mfrs using this transmissions.
Oem fluid is $55 a liter
Castrol is $5 a qt
Redline D4 $100 for 2 gallons
Any other recommendations ? I'm leaning towards the Redline
Ive looked for regular Mobil1 Synthetic ATF as shown on their site, but... All I can locate is a Mercon type in the stores.
Thank You in advance, Victor.
Castrol is $5 a qt
