Transmission Magnet forgot to reinstall..
The Woods of NY
Hey, quick question, i did a pan drop on the ciera, replaced the filter & gasket, reinstalled, filled with 6 qts of Castro HM ATF fluid, only to notice the transmission pan magnet was left out... How could i forget to put it back in the pan after cleaning everything up? I dont know..
Is it needed for say a 20K max mile OCI? That should be less then 6 months.. on the next change i will put it back in, or should i drop the pan, and reinstall it now? Its a small little magnet, pretty strong though, about the size of a oil change sticker..
Thanks!.
Just place it on the outside of the pan... That way you don't loose it... I have a magnet about twice the size of a silver dollar on the bottom of my pan surrounding the drain plug...Then I have 3 Neodymium Magnets attached to my spin-on transmission filter...I really like my magnets...
Don't bother about the magnet and a good refresh of the fluid as u did is plenty, if you could find a drain plug with a magnet that would give you peace of mind. A neatly broken down transmission catches less on the magnets.
Enjoy the hardwork and a new soup for the transmission!!
Don't sweat it. My car - a Mercedes - did not come with a pan magnet. I installed one when I changed the transmission fluid and dropped the pan.
