The transmission fluid temps in the GP seemed to normally hover in the 195-200F range under a variety of driving conditions, including highway and city driving, and the owner's manual states that the normal operating temps are 180-200F. However, I noticed yesterday that the temps were reaching 210-230F under the same type of driving conditions and ambient temps were 75-80F with relative humidity probably in the 70-80% range. My shop just replaced one of the transmission cooler line fittings two weeks ago and the entire other hose four months ago. Lubegard Red was added at the time of the hose replacement and the transmission fluid was last changed about 22k miles and 2 1/2 years ago by the PO.
Should I be concerned with these temps? If they are too high, how should I address it? Do a drain and fill of the fluid (replaces about 7.5 quarts/50% capacity), use an aftermarket aluminum transmission pan with cooling fins and built in drain plug, replace the stock cooler with a high performance transmission cooler (thinking the stacked plate MSP Desert Fox), or add the aftermarket cooler inline with the stock setup?
