Just replaced my transfer case in 98 Expedition.
Went for a test drive and transmission would not shift gears (reverse, and drive worked but would not shift out of first and then it stopped moving altogether).
Once stopped had no 2 wheel drive gears at all.
When shifting into park, gears were grinding slightly.
Was able to shift into 4 wheel drive high and 4 wheel drive low gears and got to go in reverse and forward.
Then shift back to 2 wheel drive again and the 2 wheel drive gears came back again, then same problem repeats itself.
Any ideas what is the problem?
