So I have an 04 explorer with the 5 speed auto. They are known for shift flare. Thats where the transmission gets hung up in between gears and doesn't shift right. After doing some online research I called my local trans shop. And of coarse he told me exactly what the problem was. The servo binds up in the housing of the trans and does not move properly which causes it. Then he told me that it would eventually take the clutches out too. He recommends rebuilding it and he will sleeve the housing and fix the valve body issues from the factory for 1800. I told him it was still running ok and I wanted to put it off so he said put lucas in.
I took his advise. I changed the fluid and found a mess in the pan. A bunch of black clutch particles. Cleaned it all out, dumped the lucas straight in the pan, bolted it back up and pumped in the rest of the valvoline merc V.
That was about a year ago and its still running fine. Shift flare is noticeably less and it hasn't started slipping yet. It seems a thicker fluid was a good bandaid for the servo binding and gualding the aluminium housing. Im currently at 130k which is where I here they all go out by and im hoping to get 150 of it before having it rebuilt.
