Okay, so unfortunately I was raised believing the Transmission fluid change myth that if you haven't changed the fluid and you're past 100K then you are better off not changing it. I know I know you don't even have to say it, should have changed it earlier.
I'm new to the forum and have already learned a wealth of knowledge but I'm so torn up about this and I've read so many transmission threads my head is spinning. My truck has 135K on the original transmission fluid. It's been topped off before but never changed. So now I'm torn on what do.
It's a 460LE and shifts fine and shows no indications of failing but changing the fluid now really scares me. Also, the transmission fluid is still bright red and has a sweet smell. So because I've already read the threads with half the people saying change it and half saying don't change it so I have another question.
How many of you have changed your transmission fluid for the first time at or after 100K and what were your results? Please specify if you dropped the pan to change the filter or if you flushed it without changing the filter.
I realize most of you are on top of your fluid changes so I may have no responses for people doing there first change after 100K. If only I had joined this forum 5 yrs. ago, but I was a little younger and thought I new it all.
