Like I mentioned to Molekule the SF Fluid made me a believer, but unfortunately it didnt cure the slam i had prior to the fluid replacement and the instalation of magnefine. I went to a transmission shop called Level 10 in NJ, the shop tore apart my transmission and concluded that my clutches were burnt, torque converter shot and my internal filter clogged. I have kept the transmission clean for almost 66k miles, with ARX and LC and adding the SF fluid. I have reason to believe the excess of LC that i poured probably caused the shearing tof the clutches. The Torque Converter was the result of constant high reving, but the clogged internal filter is what got me. Honda's Internal filters dont clog, luckily i had the magnefine filter to take over the job what the Hondas internal filter was unable to do, but even that too the shop tech said that the Magnefine filter was cloged,after 5k miles of use, i couldnt believe that. So he decided to remove it and advised not to put another one again.I paid $3300 for upgraded transmission parts and now the transmission feels like a heavy duty push, not really smooth, maybe because of the use of the shop's transmission fluid. What should i do? I was planning to install another inline magnefine filter , which i believe couldnt have clogged after only 5k miles and has a bypass system and i want to flush out the garbage fluid to put your SF-Z1.I just dont get how the internal filter filter clogged when it is non-serviceable and its a metal mesh screen. Please give me some suggestions,Thanks
P.S Its a 2002 Honda Accord with 66k miles and the transmission trouble started at 53k miles.
