tranny and transfer case fluid change write ups?
Carmi, IL
Anyone got a link to a write up for changing the fluid in my transfer case on my 2000 grand Cherokee? What about a trans change?
I have some stuff on the trans flush, but have had a hard time finding something about the transfer case.
Thanks!
Thanks adreed, but I posted the same thing over there too, so far nothing helpful.
Anyone?
Anyone?
Depends on what system you have..231,242,Quadra Trac transfer cases?What size engine,transmission?Need to know info before any advice is given
Oopps, sorry about not putting in what I have
...Here it is...
2000 Grand Cherokee Laredo with 4.0 engine(WJ)
4 speed atuo transmission (42RE)
Selec-trac transfer case (NV 242)
...Here it is...
Changing fluid on the 242 is a snap..upper and lower drain plugs and ATF4 is recommended...look in your owners manual.The 42RE I would take it to the dealer if you don't know what you're doing or get a service manual.I purchased the factory service manuals for every vehicle I plan on keeping a long time.They are $60 but pay for themselves the first time you use them.
wow, $60 for the factory manual? Cost me $105, not incl shipping from tenaflyjeepmoparparts.com
the 242 transfer case is simple, just atf+4, drain out the bottom hole, fill from top till level with the hole I believe.
The 42RE as far as I know is like your typical auto. Drop the pan, replace filter and refill, then pull the transmission cooler line to drain out the tq converter; there's a writeup from amsoil on that if you need it.
http://bestsyntheticoil.com/amsoil/torqueconverter.shtml
But with the 42RE, it's recommended to adjust the bands every 30k mile I think with the transmission fluid change. You need an inch-lb tq wrench, and the specs would be listed in the service manual. I've searched all over and couldn't find the #'s so I broke down and bought the book.
