The motor guy
Thread starter
- Joined
- Nov 29, 2009
- Messages
- 10,258
Originally Posted By: CapriRacer
Originally Posted By: motor_oil_madman
My tires are 205/75/R15 tires I believe. I mean the good news is tires can be found off amazon for like $50 bucks each, although I don't think they'll last long. I had a spare on for a couple day 50 miles maybe? You could visually see the wear.
To answer the first question you asked: As a general rule, you can NOT replace trailer tires with other types of tires. Passenger car tires don't have the load carrying capacity (1598# vs 1820# in ST205/75R15 LR C) - and light truck tires don't exist in the proper sizes.
If you are willing to take some time, you might be able to find something that works, but you'll need to examine the rim size (width in particular), load carrying capacity, and clearance on the vehicle (don't forget the tires are flexible and can eat up that 1/2" space you may think is plenty!)
Also, I wouldn't buy from Amazon. That is one way to guarantee that you'll get those awful Chinese tires. If you are going to do mail order, use Tire Rack or Discount Tire Direct. Better, order through a local dealer.
BTW, it isn't so much that Chinese tires are made badly, it's that the Chinese are still catching up as to what is needed to perform - that is, design! Carlisle, Maxxis, and Goodyear seem to be catching on much more rapidly in the ST market.
And trailer tires don't typically wear out. Age is the biggest reason for removal. Depending on where you live, 5 to 10 years is the limit.
So if you are seeing much wear on your trailer tires, you need to look at the alignment. (Yes!, Trailers can be out of alignment!)
I was told all the scrubbing is what wears them out. I do a lot of u turns and such. All four of mine are evenly worn out, so I don't think it's an alignment issue. I asked this question a while back and was told trailer tires especially tandem axle tires wear quickly due to scrubbing on every turn.
