Originally Posted By: MrHorspwer
Originally Posted By: JTK
2005+ Trailblazers used a pulse-width modulated fuel pump to regulate fuel pressure. It doesn't have a fuel rail mounted press reg with a return to the tank.
The #'s you posted may be correct. You're positive it's a fuel pressure problem?
Any issues with that would require replacement of the FSU I'd think.
Have you had a compression test done? Any Vortec/Atlas 4.2L valve seat issue I've ever heard of had low compression as well.
Coils can be an issue as is the MAF sensor for random misfires.
Trailblazers do not use a PWM controlled fuel pump. It is a returnless system, but a standard diaphram pressure regulator is part of the fuel sending unit.
It's also not a MAF problem; the 4.2L didn't get a MAF sensor until 2006.
As for replacing the head, I wouldn't let anybody replace it until I had cylinder leakdown results in hand. Misfire caused by a valve seat issues is most always felt only at idle. It's pretty unmistakable.
Well then you need to notify the people that wrote the factory service manual. They changed the fuel pump design in 2005.
Personally I'd try replacing the ignition switch. They are a know problem on these vehicles and much cheaper/easier than anything else.
