Chevy fuel pressure regulator info needed
Lakeside CA and Lake Havasu City AZ
Was replacing the fuel pressure regulator on my 2000 4.8L V8. The new one wouldn't push in so I pulled the o ring out and I thought it dropped into the fuel rail. I pulled the fuel rail off looking for it and cannot find it, but I found an o ring in the groove where the o ring that I thought fell into the rail came from. Are there back to back o rings that seal the fuel pressure regulator? This is the small o ring in the center, not the outer o ring around the housing.
Yeah just one oring used from what I've seen. Sometimes they stick inside and sometimes they come flying out faster tha you can see 'em.
Later models don't have a pressure regulator at the engine.
