Why guess? Here you go: (sorry the cut and paste isn't the best!) No mention of wheel speed sensors as a possible problem
Service Information
2000 Pontiac Grand Am | Alero, Grand Am (VIN N) Service Manual | Brakes | Antilock Brake System | Diagnostic Information and Procedures | Document ID: 649963
Low Traction Indicator Always On
Circuit Description
Four-way serial communication is sent back and forth between the EBCM, IPC, PCM, and the BCM. A message from the IPC is sent to the BCM within seven seconds after ABS initialization. A serial communication failure does not allow the proper warning indicator commands to be sent back to the IPC.
Diagnostic Aids
Use the Lamp Test function of the Scan Tool in order to turn the indicator ON and OFF while looking for an intermittent malfunction.
Thoroughly inspect any circuitry that may cause the intermittent complaint for the following conditions:
• Backed out terminals
• Improper mating
• Broken locks
• Improperly formed or damaged terminals
• Poor terminal-to-wiring connections
• Physical damage to the wiring harness
Test Description
The numbers below refer to the step numbers on the diagnostic table.
This test ensures that the instrument cluster can operate the LOW TRAC indicator.
Step
Action
Value(s)
Yes
No
1
Did you perform the ABS Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check - ABS
2
Turn OFF the ignition.
Install a scan tool.
Turn ON the ignition, with the engine OFF.
Select the Body menu and then IPC on the scan tool.
Select Lamp Test on the scan tool.
With the scan tool, turn the warning indicators ON and OFF
Does the LOW TRAC indicator turn ON and OFF?
Go to Step 3
Go to Step 4
3
Inspect for poor connections at the harness connector of the EBCM. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 7
Go to Step 5
4
Inspect for poor connections at the harness connector of the instrument cluster (IPC). Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 7
Go to Step 6
5
Replace the EBCM. Refer to Electronic Brake Control Module Replacement .
Did you complete the repair?
Go to Step 7
6
Replace the instrument cluster (IPC). Refer to Instrument Cluster Replacement in Instrument Panel, Gauges and Console.
Go to Step 7
7
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 2
© 2008 General Motors Corporation. All rights reserved.
