As any of y'all can tell by my "registration date", I've been lurking for awhile - but, THANX for the official "welcome",
Bandito!
Cutlass - I wasn't planning on doing anything but dropping the pan, cleaning the screen and replenishing the oil. I purchased this truck used with 100K+ on the clock, from a Toyota dealership who claimed the previous owner was a retired Air Force officer.
Therefore, I have no service records on it. Hopefully, the PO had a flush or two done at some point during his ownership - but I have no way of knowing. It shifts fine, but I haven't seen the trans oil yet, since there's no dipstick - so I'll proceed with the "tranny service" according to what the old oil looks like when I take out the drain plug.
If it's still pinkish (or close), I'll probably do as I originally intended. OTOH, if it's dark brown or worse - I'll probably grab another 2 gals of MaxLife and change out 12qts total with the more time-consuming "cooler-line method". I have a Rotary 9K hoist in my garage, so I don't have to crawl around under the truck (too old for that anyway, lol).
As a retired ASE-certified "Master Mechanic", I know a little bit about car repair/maintenance - so let me just offer some insight on the subject of tranny flushes. There's a common misconception about the so-called "100% fluid exchange" that's touted by those selling flushes (regardless of which machine is used) &/or using what is essentially the same process by doing it manually with the "cooler-line method".
The "100%" description of fluid exchange wrongly ASSumes that there's some kinda imaginary
"line of demarcation" between the old and new fluid where it "meets" inside the trans & converter.....IOW, that there's no
mixing of the two, lol.
Granted, there will be a far greater rate of fluid exchange with a proper
flush - compared to the old "spill & fill" method - by forcing new fluid in at the same rate that the old is expelled - but certainly nowhere near 100%. As a result of mixing, I would
GUESS that it might be closer to 60 or 70%, but DUNNO!! My 2¢.....
C'ya - RAY
