Ok, I'm trying to convince myself that, indeed, I can change the oil myself. I might even drop the pan and clean out any metallic debris. However, I'm getting conflicting info as to the "filter": some sources say its a filter, others say it's a strainer.
I'm guessing I lose nothing if I drop the pan and check it myself, and change it at a later date; but does anyone know? If it's just a strainer then I don't see a reason to mess with it. As it is, I'm not entirely sure I want to remove the pan, lots of work to clean out stuff that isn't going to be moving (all the metallic bits should be stuck to the magnets).
