- Joined
- Mar 5, 2025
- Messages
- 8
my bluedriver scanner said p0328 stands for knock sensor issue and needs replacement but it is all the way within the engine. The c1280 code said to replace throttle ignition sensor, good thing this one isnt so hard but i dont know where it is exactly.
ii tried removing the negative terminal on my battery to reset the ecm but it didnt work, the codes still remains as permanent. My battery wasnt the problem either since the voltage is tested to be healthy.
as of now my cars all wheel drive is disabled and there is a " no TRAC " and " check awd " notifications on my info screen. Whenever i stop and drive, my car would hesitate/jitter EVERY single time when im at the light, or stop to make a turn.
ive checked the parts cost for throttle position sensor and this one seems cheap - only 15 bucks on amazon but the other one is over 120 dollars on amazon and the labor cost to replace this might be 2-300 i think.
not sure what else i can do, my cars only 76k miles and i barely drive since i work from home.
whats the next best solution?
