I don't understand why they continue to use composite, (read cheap plastic), for these type of applications? Plastic, combined with motor oil equals sticking and seizing. Especially with a monkey at Jiffy Lube at the other end.
The plastic oil filler caps most all vehicles use are bad enough. All 3 of my vehicles have them, and even with cleaning and greasing the sealing surfaces and O-Rings, (which I do with every oil change), I still have to be cautious when I tighten them. I barely go 2 finger tight. Or else they're a bear to remove.
I can't imagine tightening mating plastic surfaces to almost 20 foot pounds. This has to be a common occurrence. I'm thankful all 3 of my cars utilize metallic, spin on oil filters.
They never should have gotten away from the old stamped metal, 1/4 turn on / off oil filler caps, with the cork or fiber sealing gasket. All they did was work...... Effortlessly. Now, it's yet another thing they've gone and, "improved".
