Code:
Honda Toyota Red RLI
Genuine Genuine Line Bio-Syn
0W20 0W20 0W20 0W20
WEAR METALS:
Iron………………………. 1 2 2 1
Copper……………….. 0 1 0 0
Tin………………….……. 6 12 8 0
Lead…………………….. 0 0 0 1
Chromium……………. 0 0 0 0
Nickel…………………. 0 0 0 0
Aluminum………….. 1 2 2 0
Titanium……………. 0 0 0 0
Silver……………….. 0 0 0 0
ADDITIVE METALS:
Calcium….…………. 1545 1809 2213 1893
Magnesium…….…. 8 17 14 10
Zinc…..………………. 833 913 1565 1041
Phosphorous……. 831 900 1219 769
Barium……...……… 4 14 2 0
Molybdenum………. 1065 1200 1290 0
Antimony………….. 0 0 0 206
CONTAMINANT METALS:
Silicon…………….… 3 42 33 1
Sodium……..………… 3 5 34 10
Boron……….……….. 63 184 19 13
Potassium…………. 0 0 0 0
Vanadium………….. 0 0 0 0
PHYSICAL AND OTHER:
Viscosity 40°C 40.4 40.2 43.4 43.5
Viscosity 100°C 8.7 8.9 8.3 8.4
Viscosity Index 203 212 171 174
Flash(CCCFP)°F 410 375 395 410
TAN…………...………… 1.40 1.83 2.12 0.61
TBN……..…………….. 5.2 6.7 6.8 6.3
Oxidation…………. 16 15 158 152
Nitration…………… 4 6 7 6
Water by KF……. 1226 1490 1676 1553
Fuel……..………….. 0.07 0.62 0 0
Soot………..……….. 0 0 0 0
Glycol……...….. 0.12 0 0 0
Sulfate byprod. 22 20 106 122
This VOA is from Dyson Analysis, which has an exclusive agreement with MRT Laboratories for their premium test kits. For comparison, I’ve inserted the Toyota VOA between the previous 0W-20 oils, since all four samples were recently tested by the same lab. See the previous thread for a discussion of elemental readings, flash point, KF, etc.
Toyota 0W-20 is probably a Group III-IV mixture. The manufacturer is still not known, perhaps Eneos. When I opened the bottle, I noticed the rancid smell of esters, as I did with Mobil 1 Extended Performance, Red Line, and RLI (but not Honda). This is speculation, since I can’t confirm the presence, type, or quantity of esters without further chemical analysis.
The Toyota 0W-20 had stirred up my curiosity, since rcy had mixed results with his labs. Don’t worry, rcy, not every result is different from Wear Check and Toromont (ha).
Some numbers are higher: moly, silicon, sodium, calcium, phosphorous, zinc, etc. This could be because Terry’s lab uses a Rotrode Spectrometer, which can measure particles up to 10 microns (not 2 microns like ICP), so the ppm will be higher. Terry did double-check the moly reading. To avoid this kind of issue, everyone who orders a used oil analysis should order a VOA from the same lab.
I noticed that the Toromont viscosity of 8.85@100° C is very close to mine at 8.9. While the flash point at 375° F is lower than the others, Terry did not think this was cause for concern. Also, please keep in mind this is using the Continuously Closed Cup Flash Point (CCCFP), so add 30-50° F to get the Cleveland Open Cup (COC).
0W20 0W20 0W20 0W20
WEAR METALS:
ADDITIVE METALS:
CONTAMINANT METALS:
PHYSICAL AND OTHER:
