Originally Posted By: bdcardinal
had more than a few cars brought it that were towed while in gear. the engines overreved and floated, then broke valves.
Well, one would assume that he'll be towing in neutral. Let's hope so.
Yes, in theory that would work just fine- towing with the
automatic transmission in neutral with the engine idling. The pump will be running... should be fine. Of couse, if you're towing a car that way long-distance and the engine dies for some reason and you tow it 2 hours with the engine shut off... you'll likely need a transmission.
Same goes for a manual, really. I gotta disagree with Omno here. You can tow a manual-transmission vehicle in neutral for short distances, but if you're towing for any significant distance or at highway speed with the engine shut off, it can tear up even a manual transmission. Most manual transmissions rely on the countershaft to be spinning to sling & distribute oil through the transmission- and the countershaft will turn ANY time the clutch is engaged with the engine running (neutral or in gear). But when flat-towing with the engine off, only the output shaft will spin... and it's usually well above oil level.
And it won't get proper lubrication when the engine isn't running.
The RV crowd has several favorite vehicles- most of them small, light 4wd's (the geo tracker and assorted Jeeps come to mind- I'm sure there are others). They can flat-tow these vehicles because the transfer case can be disengaged... so that the output shaft of the manual transmission doesn't turn. Can't do that with just any ol' manual-transmission vehicle, though.
