Toughest battery I have seen.
Apple Valley, California
About 12/2018 a car was towed to the radiator shop I worked at for a leak.
Leak was a hole in the block where a rod had went out.
This battery was in the car and has a 11/2018 date code.
Could not get a hold of the customer and they never returned our calls. Car sat out back untill 10/2020 when the shop closed and the car was scrapped.
I grabbed the battery just to have a core if nothing else. It had 0 volts at the time.
I put it on a charger just for kicks. It came back to life.
It's rated @525cca....tested @650 cca!
I stuck it in my tractor for a year or so. Then the two 6v batteries in our trailer died so I stuck it in that just to run the generator occasionally.
It has finally died. Shows only 125 cca available.
Nearly 4 years of total abuse. I'd say it lasted very well. Of course the ones I have bought reciently are failing after just 1 year.
