Total/ELF vs. Store Brands
Originally Posted By: AudiSport
Well in my platform, we want at least 200*F
+212f = +100c
That's the temp the visc for the SAE label is taken.
Above that, it's thinning substantially, that's why you want a thicker oil. When a 40 weight heats to about +225f, it thins from 14cSt to 10cSt, which you don't want to get below. Above +225f, you are looking at a 50 weight needed to keep decent visc.
I wasn't sure if the celsius and farenheight got mixed up on your end.
^ Thanks.. I'm kinda still @ a loss here with all the different recommendations.. On the Audi forums, oil is whatever cup of tea you prefer it seems, on here I'm overwhelmed with information HAHA. I need someone to make a definitive answer for me! I'll only have this oil in for 3,500 miles like I said, and I'm really just looking to make it a little bit easier by going to the store shelves rather than having it shipped. I do however daily drive my car more so after the summer, right now I kinda just joy ride it as I'm working in NYC. I do a lot of tuning/logging with the car where I bring it to redline in 3rd, etc, so I was just looking for a good oil that can still provide the same that Total did, whatever that was exactly!
+212f = +100c
Oh, I see what you're saying now.. That's good to know how the oil breaks down after that rating. I gotcha ! So for the summer months, I will try to find myself something a bit thicker. Like I said I've seen so many different recommendations now I still don't know what to look for when I go to Advanced. Mobil 1 is not great, right? I can look for the Valvoline or PP.
The SynPower 20w-50 is the best 50 weight around, and it seem like that's what you need based on your reported oil temps. You can thin that w/10w-30 as needed as it gets cold, but watch the oil temps stay in the right range for the mix you've done.
Basically, I suggest customizing your own oil for the seasons. The thick oil you need in summer is too thick for the cold. Right now, SynPower 20w-50 is a good start.
The term synthetic is a whole thing unto itself. There are a lot of different definitions. An oil like Shell Rotella is labeled synthetic, but is a Groupe III "slack wax" base oil, same as in their high end Shell Helix Ultra, that Ferrari charges $50 a quart for. Europeans used to consider only GIV and GV as synthetics, but has since included GIII in their definition.
That being as it is, SynPower 20w-50 is one of the only GIV (PAO) base oils on the otc market, and one of the only 50s as well. You said you wanted an equivalent to a Euro oil.
5w-40 might work ok for you in the spring and fall, but you do need a 50 in summer. Come winter, you will need to find another solution because of your extreme climate.
You're the man! Thanks for all your advice/info/knowledge/everything you've provided.
Is this true of ALL the SynPower weights (not just the 20W-50), as well as the SynPower Racing oils?
(I am asking this because I really want to know, I am NOT trying to knock/disparage the Valvoline product's quality!!)
Is Royal Purple a scam or is that pretty good oil? I certainly don't have any data myself, I'm just curious as to opinions.
It's purple, don't you get it?
AS, here's a google search of BITOG for Royal Purple. Should be plenty of information, pro and con.
http://www.google.com/search?hl=en&a...nlo=&as_nhi
Also consider googling for Royal Purple, see what is said on other sites.
I'd like to know this as well.
German Syntec and probably Mobil 1 0w-40.
Base oil is really a non-issue. It's just part of the formulation.
I would skip the Mobil 1 15w-50, but if you could find Pennzoil Platinum 15w-50, try that.
Not sure why we are skipping Mobil 1 15w50. It has always seemed to as well as Mobil 1 Turbo Diesel Truck and Rotella in used oil analysis is gas engines and has higher additive concentrations. I know you know a guy and all but still Mobil 1 15w50 has been highly regarded here as a tough oil, unless things have changed in the past few months.
I don't know what happened to my post on this, but my MASTER Porsche Mechanic whose Dad is a 35 year Master BMW Mechanic who also happens to hold a Full Competition Race Licence says he sees many blown engines on Mobil 1 Red Cap, where another brand's 50 weight averts problems under the same conditions.
This isn't me, because I don't use the stuff, but someone who is OVER qualified to say so. Heaven forbid I just post my opinion.
