I like Husky and Kobalt because they have a lifetime warranty. Swap them out every few years. Just say the ratchet isn't working right
You can do that with even the least expensive Harbor Freight torque wrenches also. I had to do it with my 1/2" low dollar one. I brought it in and told the guy the problem. He immediately walked over and grabbed a brand new one for me. Took only a couple of minutes and I was on my way home. If you look at the 7,122 reviews you'll find a strong satisfaction rating:I like Husky and Kobalt because they have a lifetime warranty. Swap them out every few years. Just say the ratchet isn't working right
When I bought the Precision it was close to what they charge for the Icon today but not anymore, today it is $200+. The Icon is not a bad tool.precision instruments split beam made in USA same price as ICON from HF. Just scope out the exactly range of torque you're looking for. I have the big blue one in that above video and the smaller 3/8 that goes up to 100 ft/lb. Very accurate and easy to use. Don't have to return the dial down at the end of use. The smaller 3/8 I had re-calibrated after using it at near max for wheels for about a year or two, which was a mistake. I then bought the bigger one that goes up to 250. Use google shopping and find the best price, buy USA once and call it a day.
I wouldn't go with a harbor freight torque wrench. I purchased one ten years ago or so and on the low end it's not accurate. I snapped bolts on my brake calipers when they called for 20 ft. Lbs go higher end.Agreed; Tekton or Harbor Freight might make sense. I do not own either one; others can chime in.
This is why the quality 1/2 inch wrenches usually spec a range of 50-200 ftlb. I wouldn't trust any 1/2 inch wrench at 20. Its likely almost impossible to get the same wrench calibrated from 10 to 150, although I know they advertise it.I wouldn't go with a harbor freight torque wrench. I purchased one ten years ago or so and on the low end it's not accurate. I snapped bolts on my brake calipers when they called for 20 ft. Lbs go higher end.
Except split beam type, you do not need to change from the last setting. I store min with 90lb.ft.What ever one you go with remember back it down to min to keep it accurate and store it in its case
I probably wouldn't either, at least in the entry level HF torque wrenches. Except perhaps a 1/2 model to keep in my truck for wheel lugs and emergencies. I do find the Quinn and Icon interesting, but don't own them.I wouldn't go with a harbor freight torque wrench. I purchased one ten years ago or so and on the low end it's not accurate. I snapped bolts on my brake calipers when they called for 20 ft. Lbs go higher end.
