Originally posted by EmbarkChief:
I always thought the whole reason for buying/building a 3/4 ton or larger truck was for towing? If a 3/4 ton truck can't tow well, then what's it good for? In addition, why are you calling his IH a Farmall (wasn't that the AG devision of International?)? Its not a tractor.
Okay, first of all - alot of people buy 3/4 ton trucks because, while they don't use them to tow, they put them through severe service and the general thought is a 3/4 ton truck will hold up better.
Prior to '99 if you wanted a 4x4 Ford with a solid front axle you had to buy a 3/4 ton. The F150 & F350 had the "twin traction beam" front end.
Third, a high number of 3/4 tonks on the road today are bought as multipurpose vehicles - a daily driver and occational work truck.
And (I hate to admit this), some people buy 3/4 ton trucks because they look cool.
If I was going to buy a truck for the pure purpose of working / pulling, it wouldn't have an auto transmission. I would also make sure I bought a truck that was geared with this job in mind. Very few of these trucks I descibed exist at the dealerships and you rarely see them on the road.
My whole point being that the Ford F250 (probably built with comfort in mind and designed for comfort) was comapred to a Farmall pick-up (built for work). This is like comparing apples to oranges. A comparable Ford may have done much better than the one in question. In '73 pickup's were designed for work, today you have a choice.
As far as the Farmall name (it was not meant as a slam), this is just what I have called all International Harvesters for years. The fire department I used to work for had a '64 IH / Central pumper. I called that a Farmall too. This even includes the Cub Cadet up until MTD started to make the smaller ones. IMO, MTD never earned the Farmall nickname.
edit: as per the above link posted by Chris142, his truck isn't stock. I realize he wasn't putting Ford down, but many other have begun to slam the Ford. Once again, this is like comparing a Ford Taurus SHO to a regular chevy Lumina. His truck also has the 392 ci engine while the smallest engine available in that truck was a 345 ci. The 5.4L is the smallest engine available in the F250 - once again apples and oranges.
[ November 17, 2004, 01:53 PM: Message edited by: medic ]
