If anti sieze is used on wheel lugs (not saying that it shoud be), how is the torque setting determined? More or less than the spec? How much?
quote:
Originally posted by PRRPILL:
The torque setting is based on dry threads. Coefficient of friction of .2. Find out the Coeficient of friction of the anti seize, compare it to .2 and adjust the torque by that amount.
Example. Dry stud B.8 100 ft/lbs. .2 friction
Anti Seize Coefficient of friction at .1
.1 divided by 2= 1/2 X 100 ft/lbs. = 50 ft/lbs. for same bolt stretch.
Scource. EPRI
U-h-h-h-h.... so what conclusion are you going with ?quote:
Originally posted by ChiTDI:
OUTSTANDING.
Thanks
2K2AcuraTL hit it about as close as anyone can get. It's about a 20% to 30% reduction by the numbers.quote:
Originally posted by dkcase:
I'd want to go to the source and read for myself before I used a torque value only half what is specified.
I would agree with this, Lug nuts are somethings that shouln't be lubed. IMO, wheels should be unbolted enough to prevent seizure from happening. Tire rotations, brake inspections, etc lend themselves to keeping wheel studs fairly clean.quote:
Originally posted by bheinz57:
And regarding lug nuts and puting antiseize on wheel studs, I always was told that doing that was a no-no. Is that just because of the characteristics of the torque changing or was the lug nut more likely to loosen because of the antiseize?
