To change or not to change.
the South
That is the eternal question.
Factory interval is 7500 miles normal/3750 miles severe service.
Oil was changed in March with Quaker State Ultimate Durability 5w30 with a full can of MOS2 with a PureOne oil filter. Currently at 7200 miles. Usage is 75% highway 25% city right now. It can sit for two weeks at a time, then rack up plenty of miles for a trip. I have a 1500 mile round trip next week.
I'll be pulling a sample after this trip for a used oil analysis, at about 9K miles, hoping 10K is reasonable for this oil. Fighting the "fresh oil before a trip" bug real badly though.
The TBN of Quaker State Ultimate Durability is not that high, 8 or close to it I think, 9 or 10 is probably its max limit but who knows. I have used it once in my Frontier, seemed to do well over a 5K duration but it was the only one I actually put make up oil with at 3k miles, about a Quart. Not enough to lose sleep over but I did find it odd that it has a low NOACK and was the only brand of synth. that I had to add to. Ran fine though, wont knock it, just don't know about using it for 9 or 10K.
Why not pull a sample and run the oil analysis now to see how much life is left, then decide whether to keep it in for the road trip or change it before?
I personally still think you're good to go on this oil. Including the road trio, you'll be at around 90% highway miles. And my guess is that the manual schedule is timed for conventional oil.
If you are trying to figure out what a safe OCI is then do this.
Because if I drop it in the mail to Blackstone Monday, I still won't have the results before I leave Friday.
And yes, the manual is based on 2003 conventional oil.
Quaker State Ultimate Durability is more than capable of a 10000 mile interval.
And initial tbn is hardly relevant,tbn retention is what matters and because of the boron in Quaker State Ultimate Durability tbn retention is great.
Where exactly are you getting your info,or kinda info or whatever that post was. I suggest reading more while your here and retaining the info gleaned
Just sayin
Op
Personally I'd change it and only because I've got stock and its autumn which is time for me to go thinner in my vehicles due to ambient.
If you life in a warmer climate like the south or pacific southwest I'd would leave it alone and change it once your home.
I would change it in your situation, but it's probably not necessary. What effect does the additive have on your confidence?
Does this old Subie require adds?
It would be pretty exceptional if it didn't.
Assuming it does, the adds are refreshing the oil's add pack which will allow longer drains if desired.
Given what you're trying for, go ahead and run the oil for your trip and then change it and take a sample when you get back.
The used oil analysis will give you an idea of the suitability of Quaker State Ultimate Durability for a longer run in your car as you use it.
I'd say your driving is normal, not severe category. If it's spec'ed 7500 miles for conventional oil, I don't see why the Quaker State Ultimate Durability needs changing before your trip. If the oil level is below the dipstick full mark, top it off with more Quaker State Ultimate Durability for your peace of mind, and change the oil when you get back.
What do you think is going to happen if you slightly exceed the "life of the oil"? I say nothing. Maybe, just maybe, there might be slightly more wear during the last 1,000 miles. If this wear is %20 greater than usual, it's like an extra 200 miles of wear on the engine. Not a concern. It's not like the oil is going to fall off a cliff property wise.
You would learn more with a used oil analysis after the trip.
I would run it, and UOA after the trip. No guts no glory haha
Ah, I see, living on the edge, I like it!
If you're still considering not changing it, but want a little more peace of mind, you could do like some others have suggested and top it off with a half quart of fresh oil, should boost the TBN a little bit (assuming you're not at the max fill line already).
Good luck, and have a good trip, where are you headed?
Nope, no top up required. I've had the car since 63K and like clockwork it uses about .25-.50 quart per 5000 miles. Dipstick is still fine at this point. Manual specs for 4.5 quarts, but I've always put in the even 5.
With Quaker State Ultimate Durability being a Dexos1 oil I'm pretty confident in it.
East TN - Chicago and back.
FWIW, the Lubry-Moly MOS2 is to see if the higher Moly helps the classic Subaru piston slap quiet down some. MPG improvement is within margin of error, so the jury is still out if I'll run it again.
I'd change it. Given the longer mileage interval nature of Quaker State Ultimate Durability, you will probably be ok. If you are a typical BITOG OCD (like me) then go with the change. As for me, I would rather take a longer trip on clean oil. The thought of dirty oil scrubbing the cylinders over 1500 miles at high speed gives me the shivers.
If you leave it in please publish the oil analysis so we can see how it is performing.
