Tire suggestions for medical issue
Hi. Taking suggestions for the smoothest (and quietest) tire possible. Recently started driving again after suffering a stroke in '23. The stroke left me with nerve damage and vibrations aggravate my condition. Current vehicle is a '22 Mazda CX5 (stiff suspension and not the smoothest engine out there) with stock 225/55r19 Toyo A36. I am hoping a smooth/soft tire can help minimize vibrations to some degree before going to the more expensive alternative of changing vehicle. snow traction is not a concern but wet weather is.
What is, in your opinion, a super smooth and quiet? Thanks.
I don’t think tire choices will make a big enough difference in this chassis - that was designed to be stiff and handle well. You would have to change shocks, and perhaps springs, and I doubt anyone makes softer versions of either
A good used Mercedes sedan, base model, with the highest profile tires that model comes with. No AMG packages or aftermarket wheels.
I can't tell you how much improved the ride was on our Audi Q5 going from the stock Continental CrossContact-something-or-anothers to the Continental DWS06+ tires. Handled better, was quieter, and amazingly smooth over bumps. I want to get them on the Pilot as soon as I can justify doing so.
I'm missing a disk in my back. So I also need a comfort ride with minimal impacts. My Buick Park Ave rides very smooth with Hankook all season tires. Best tires I ever owned. Take minimal weights to balance, very round, good wet and dry handling, comfort ride, and hold air pressure longer than any other tires I've ever owned. My Hankook are the best tires I ever owned.
They cost me $1 each because they were a warranty replacement for General all season tires I'd bought. The Generals weren't round enough, vibrated on highway, and rode stiffer than I liked. I tried to buy tires from an American company, but the Generals were a miserable fail.
Hankooks are South Korean. My second favorite tires are Cooper all season tires (a close second) and they're American made. The General, Hankook and Cooper are all midgrade, midprice tires. The Cooper, and especially the Hankook, punch above their price. Uniroyal are cheap lowend tires, but I've always found Uniroyal all season tires to work well and have a comfortable ride.
If money is tight, I recommend Uniroyal because it rides smooth and punches well above its price, IME. Otherwise Hankook followed by Cooper. The only reason I put Cooper after Hankook is that IME Cooper need more balancing weights than Hankook.
If money is no object, Michelin is reputed to be the best, but they're expensive. I've never owned a Michelin.
IME, Toyo ride rougher than I can tolerate.
In summary, buy new wheels (smallest wheel that fit the caliper).
Then replace the tire with the appropriate size for that smaller wheel with taller sidewall to provide better cushion.
Make sure you buy good brand tires not the cheap tires.
That defineately does help a lot. I've done that with Jeeps.
If getting new wheels, get aluminum, not steel, wheels. Aluminum are much lighter, which reduces unsprung weight, which provides a somewhat softer ride. Lighter wheels also help acceleration, braking, and gas mileage.
Some shocks offer a more comfortable ride vs others that offer higher performance (better high speed cornering).
Also, too high a tire pressure can stiffen ride a lot, but too low can be bad in other ways. You need to figure out an appropriate tire pressure. That's probably printed on a label in drivers door jam. It's not the pressure printed on the tire sidewall.
Thanks everyone for the thoughtful suggestions and for the well wishes!
I am considering the switch to 17 inch wheels+tires. If that proves too expensive then I think the Pirelli Scorpion A/S 3 fits the bill. I'll report back asap. Best regards.
Check local Facebook listings.
Had a 16 cx5 with 17" wheels and a 21 cx5 turbo with 19" wheels. I should note that I took lots of road trips with both vehicles. My goal was to improve ride quality and reduce noise without compromising Mazda's great handling. I had Continental Cross Contact LX25 on the 16 cx5. Those were a big improvement over the Yoko's that came on it. They were much quieter than the Yokos. The Yoko's seemed to wander a bit and seemed touchy to variations in tire pressures. I put Pirelli As Plus 3 Scorpions on the 21 and those transformed that vehicle. It came with Toyo's that wore out in 24K miles. The Toyo's weren't terrible and rode OK. The handling was acceptable they just had terrible wear and got too loud at interstate speeds. The Pirelli's were plush riding for being on the sporty side. In my opinion, and even though they were the bigger tire, they were more comfortable than the smaller Conti's. Handling was still very good but they were so much quieter than the Toyos and even quieter than the Conti's. The Conti's seemed a little firmer than the Pirelli's but certainly not overly so. The Pirelli's absorbed big hits with more composure. If I had to do it again I'd go Pirelli's as my first choice followed by the Conti's.
General Tire is a German company.
Tirerack has some nice wheels available for $200 each from Enkei who makes a lot of OEM wheels for various Japanese auto manufacturers. Check out the PX-10 in grey or gloss black. Weight is around 17.5 lbs. each with excellent reviews.
I know this an old thread so OP might have already bought tires but I have a 23 cx5turbo as does my brother in-law..he has Pirelli Scorpion AS tires and I have Michelin CC2 tires..both put on about the time...there is zero difference in smoothness between this tires. we have ridden in each others vehicles many times. both are smooth quiet tires...we both do lots of longer road trips..the CC2 are excellent in the rain.
General is owned by Continental. Continental is German. So perhaps that makes General a German company, or at least owned by one, but I think General is located in USA, or at least partially so.
General tires (or at least the ones I'm aware of) are made in USA, Mexico, and Canada and marketed and sold in those 3 countries. So I consider General to be a North American tire.
However, I did not like General All Terrain tires on my Jeep due to very harsh ride. Later, I did not like General All Season tires on my Buick because they weren't round enough.
So at that point I don't care where they're made because I don't like them.
As many have pointed out, tires, wheels, and shocks can all make a signifigant difference to ride quality, especially considering the cumulative effects of those things.
However, as @Astro14 pointed out earlier... If those changes combined don't make a big enough improvement to ride quality, you'll have spent a lot of money and end up having to sell the performance car to get a softer riding type of car (ideally a classic luxury car).
And your performance car might be more difficult to sell (or worth less money) after you made modifications that reduced performance to increase ride comfort/smoothness.
You might be better of buying a classic luxury car like a Buick Park Ave, Mercedes Benz, or other luxury car. Over the years I transitioned from Jeep Wrangler Rubicon TJ/LJ (brutal ride quality) to Cherokee XJ to Park Ave.
I modified the Wrangler Rubicon to make it ride better/softer/more comfortable. After spending too much time and money, I succeeded in getting it to ride like a normal Wrangler, which was a big improvement for my spine, but it was still hurting me too much.
So I had to sell the modified Wrangler Rubicon (losing more money in the process). The demographic who likes Rubicons and modified ones isn't seeking one with the comfort mods that I'd made. So in addition to spending money on mods, my mods also reduced resale value.
The Cherokee XJ was more comfortable when stock. I modified it to be even more comfortable than stock. It was then acceptable for ride comfort. But then my spine health deteriorated again and then the Cherokee was causing me too much back pain. I had to sell the Cherokee XJ. My mods didn't lower the value of the Cherokee, but didn't add to the value either. So I lost the signifigant cost of mods. At least it was less financially painful than the Rubicon had been.
Then I bought my Buick Park Ave and it was a huge improvement in comfort. I did suspension maintenance, two mods (shocks & swaybars) and good tire choice that improved it's comfort even more. People comment on its excellent ride quality because they're impressed (even when I haven't mentioned that it's modified slightly).
I should have bought the Park Ave in the first place.
You can give a pig a bath and put lipstick on it. It will then be a better smelling, more attractive pig, but it's still a pig. Buy an appropriate car and then if/when needed - choose good tires and shocks that will ride well. Your tire store can help you choose tires and shocks for your special needs, but that is most helpful when you have an appropriate car.
You'll get better results for less money if you buy an appropriate luxury car that already rides smooth. Whether it's a Park Avenue or a Mercedes. It doesn't have to be expensive to ride well. Though it does have to be well maintained to work properly.
The profits still go to Germany.
General tires are also made in Germany, too. They can be made in any factory in any country owned or operated by Continental.
Conti branded tires can also be made in General factories in the US or Mexico, as well as their own. The problems you experienced with General tires have also occurred in Conti's own tires.
Any tire brand Conti owns can be made in any factory anywhere in the world.
