Tire suggestions for medical issue
Hi. Taking suggestions for the smoothest (and quietest) tire possible. Recently started driving again after suffering a stroke in '23. The stroke left me with nerve damage and vibrations aggravate my condition. Current vehicle is a '22 Mazda CX5 (stiff suspension and not the smoothest engine out there) with stock 225/55r19 Toyo A36. I am hoping a smooth/soft tire can help minimize vibrations to some degree before going to the more expensive alternative of changing vehicle. snow traction is not a concern but wet weather is.
What is, in your opinion, a super smooth and quiet? Thanks.
Michelin and Continental. Don't look elsewhere.
Check the Michelin Primacy lineup. That is basically their comfort-oriented lineup of tires.
If you need snow performance, Michelin CrossClimate2.
You can use smaller wheels with tires that have more sidewall. Tire rack even sells pre-mounted tire and wheel packages that ship right to your door so a family member or friend can put them on for you (or they could ship directly to the shop of your choice) :)
So, the best option would be to get 17" wheels with some tires. The new tire size would be 225/65-17. The Toyo Celsius II is a good choice for you.
Cross climate 3 should be available shortly I believe. Hold out for the improvements!
They will be marginal. CC2 is already a well-rounded tire.
Considering it is September, CC3 is supposed to be out a month ago. I would say they are skipping this winter in the US.
The 19" wheels and 55 series tires are going to be stiff(er). 17" wheels with 65 series tires also came on that model and would be a softer ride with the taller sidewall. Best bet for ride quality info across brands would be to read reviews on tirerack.com and discounttire.com A standard touring all-season or summer tire should be softest. Stay away from performance tires.
A set of pre-mounted 17" wheels/tires is a good suggestion.
Glad to hear you're well enough to drive again.
Yep. I would do that.
1. It will improve comfort drastically.
2. Tires will be cheaper.
3. There might be less unsprung weight, hence, better mpg and acceleration.
I bet he can find used wheels on Facebook.
If I can suggest landing on your tire size and then research noise and comfort ratings on tire rack. I'm a fan of Pirelli Scorpion Verde.
Can you downsize the rims?
That may have even bigger impact than tire model/brand.
Krzyś
PS Late to the party and the same suggestion was posted a few times earlier by others.
When we bought out 17 CX-5 , i had them swap the 19 for the smaller wheel 17. Overall diameter was the same. Ride is very comfortable. Perhaps look for some mazda CX5 wheels in 17 inch.
