- Joined
- Jun 19, 2024
- Messages
- 276
To the OP.
Next time you get an alignment get them to set the front camber to -1 to -1.5 degrees, not just 'to spec'.
They may only be able to get max -1 degree with stock bolts which will still help a ton.
Whiteline lower bolts will help get more neg camber if you need it.
Subaru's need negative camber, especially if your doing a lot of spirited or Mountain driving.
I've read of people running -2 deg on street without reported issue.
Your tires will last longer and may notice slightly improved handling.
