Originally Posted By: gabriel9766
the car in my signature, 2015 chevy malibu with 215/60/16 as the tire size.
Oops! Sorry! [Note to self: Look in the signature next time!!]
OK, 2 possibilities occur to me:
1) It's an old tire engineer's trick to use less tread depth in the shoulder ribs to improve rolling resistance. Maybe this tire started off 1/32nd smaller and has stayed that way - so in some respects, it is wearing evenly, it just didn't start off even.
2) Steer tires tend to wear in the shoulders. I wonder if what you are seeing is an artifact of that - and over time it will continue to get worse.
Suggestion: I don't see any harm to boosting the inflation pressure by 3 to 5 psi. Then very precisely measure the tread depths - to the nearest tenth of a mm if you can. You'll have to do it in at least 3 spots - and I would suggest 6 evenly spaced places if you can. Then in 10,000 miles, do the measurements again. See if that is having the effect you want.
Just an FYI: Radial tires aren't as wear sensitive to inflation pressure as the old bias ply tires used to be. There are lots of things that have a greater effect - such as alignment.
