I had some new tires installed recently on a 2014 Toyota Camry and the sidewall said max pressure 51 PSI. I always re-check the tires and the Lugnuts within the hundred or so miles after having new tires put on any vehicle. I checked the tire pressure and all of these tires were set at 34 to 35 psi. I bumped that up to 41 PSI and it made me curious as to how close do you get to the max PSI number to get good performance from your tires without being unsafe so I figured I'd post this question and my favorite forum! Thank you in advance for any helpful feedback
