Tire over inflation
WV
Today I had my tires R&B at Costco. When I got the receipt it said the rear tires were inflated to 39#. I like to run 35 so I backed into one of the self service inflation stations. You set the pressure to what you want and it either adds or removes air(nitrogen). The rear tires had 50# and the front had 45. Max inflation on the tires is 50 #. I asked one of the tire guys why they would put 50# in them. He pointed to the door jam label which said 45/48. I've always been told to follow the manufacturers label on the back of the gas door which states 32/32 normal and 41/44 for max load. Running 35/35 is a comfortable ride and I'm getting good tire mileage.
So who out there runs their tires at max pressure? I would have bounced all the way home if I had left it in there.
The recommended specs for my truck with the factory tires is 60F/80R. With factory tires I used to run around 50psi.
With 37x12.5-17 tires I only run 35F/30R. They still have more load rating at that pressure than I will need(and more that the truck is rated for). Most guys get bent out of shape about those pressure in a 1 ton truck but it rides great and the tires weR perfect. I also chalk tested them a few times and they are perfect.
Old style gauges, are as good as guessing how much air is in the tire.,,,
That really depends on the gauge. Lots of analog gauges out there that are more accurate than lots of digital gauges. (I worked at a place that calibrated gauges once)
It's not uncommon for there to be a wide range of pressures recommended by the manufacture for different conditions, loads, speeds, and tire size options. In the USA, it's more common for them to standardize on a single "one size fits all" or sometimes "2 sizes fit all" door placard spec, however, find the manual for the same car published in Europe, and there's often a table of pressures, sometimes with different pressures for each axle, for different conditions and loads. My S60 has pressures from 32-44PSI recommended depending many factors. You ML probably does have valid tire pressure options from ~32-48PSI.
I hope you're trolling us...
Why would you adjust your tire pressure for a tire that may not be manufactured anymore?. You can run a tire pressure as low as you want depending on how your using the tire. I'm not talking off road or high performance use. But for normal street use, You will never go wrong setting it to what the new tire is rated for...
I don’t know if either of my vehicles has a tire pressure decal on the back side of the gas door. I haven’t even payed attention to it. I go by the decal on the door pillar.
You and tacticaldriver would get along - hey, if 35 is OK, then 50 is good, and 65 must be better!
https://bobistheoilguy.com/forums/threads/fill-to-vehicle-spec-or-tire-spec.154557/
Not one vehicle manufacturer suggests using sidewall pressure - that is a maximum limit for the tire, not a recommended pressure.
Start here: http://barrystiretech.com/inflationpressure.html
Unless the pressure on the door is for the same brand and tire on the vehicle, I set the pressure to whats on the tire. Never had any issue doing it that way. I also only use a digital pressure gauge. Old style gauges, are as good as guessing how much air is in the tire.,,,
BigCahuna,
We've had this conversation before.
What's on the sidewall of the tire are maximums. Even says so!! Those are not recommendations or even suggestions.
And the doorsticker? It's required by the government. It has a size, but doesn't have the tire brand - and that's because it doesn't matter who makes the tire, but the size does matter!
Wait, your door jam and gas door disagree? What's going on here?
I'm with eljefino - that doesn't make sense.
Perhaps the fuel filler door has a couple of options depending on various conditions - one of which will match the door sticker! Use the door sticker!
