I have 3 tires with reasonable tread and one with worn outer edges due to previous owner's not keeping the tire properly inflated. I tried to get one new tire from Walmart and run it along with my spare (which is perfect tread but need to start using before dry-rotting destroy it.) The problem is that Walmart doesn't carry 265/75/15 which is what my 94 Bronco use. It doesn't have the 235/75/15 stock but rather a larger version found on later Broncos.
I went to Merchant and they want to charge me $165 for one tire size 265/75/15. We're talking about regular Goodyear Wrangler that Walmart sells for 78 dollars for the 235/75/15. I asked what's their price is for the 235/75/15 and they list it at $145. Their price is a lot more expensive and they don't match price because they will find a reason to say two tires are different some how. Needless to say, I'll never buy tires from Merchant.
The dilemma is that I need to replace that worn tire before going in for inspection later this month. I plan to only drive 2500 miles on average so I can't justify throwing away 3 good tires and replace all 4 tires at Walmart. I don't know what is considered acceptable wear but the 3 good tires I have now have decent tread, probably about 1/4 left. That is good enough for accoasional errands.
My options are:
1) Put the spare tire on where the worn tire is and go in for inspection. Then swap back since I don't drive that much, only once a week to the dumpster to throw 3 bags of trash weighting less than 6 pounds total. I am going to drive it once a week just to keep things lubricated. It is the same day I plan to use the vehicle for around town so we're talking about less than 30 miles total at low speed.
2) Get a used tire from used tire place and hope that it cost under 40 dollars out the door.
3) Get 1 new tire and use that along with the spare tire for the rear and take one good rear tire to use it as spare tire.
4) Get 4 new rims and put 4 new Goodyear Wrangler at 235/75/15 from Walmart. Rims will be about 90 dollars for the aluminum stuffs looking like steelies. Then take existing wheel set to use in winter and potential off road.
5) Get 4 new rims and put 4 new tires but buy the very aggressive off-road version of Goodyear Wrangler at about $160 each and get 4 rims for that. Put the new wheel set on to get pass inspection and switch back to existing setup for local use. Then when the weather gets bad or I am doing road trip, put the good stuffs on.
Please advice.
My options are:
Please advice.
