Tiny magnetic particles in my oil filter. Oh no!!!
KY, USA
I have a 95 Camaro Z28 with a modified LT1 (SBC) making around 450 FWHP. Engine runs perfect thropugh and through.
Every time I change the oil I cut the filter open for analysis. Every time there is a generous amount (3-2 particles per pleat average) of very tiny shiny silver particles that will be attracted by a magnet. Again they are very small but numerous. The magnetic drain plug will also show a very small amount of fuzz on it which most will consider normal.
I really believe that the stuff in the filter is the stuff that the magnetic drain plug simply did not catch. Never any chucks or larger fragments.
Should I be worried about this or is it normal?
Thanks in advance for all replies.
its probably all that FRONT wheel horse power thats doing it
How do you cut open your filter? Tubing cutter or saw? If its a saw or carbide disc on a dremel tool - ignore what is in the filter - prob came from the sawing. Engines will generate about 1 tsp of wear metals per oci. - look like you getting a lot of iron from cams, rockers or gasp cyl. walls. A bit of fuzz is OK. What oil and filter? I hope its a light HDEO or Brad Penn race oil - or at least Mobil 1 10w40 or 5w-40 Shell Helix Ultra.
In short: No, metal in your filter isn't normal. I've never had it in anything I've ever owned.
I have to agree. It needs further investigation. What oil and filter are you using?
I'm pretty sure he's meaning Flywheel Horse Power
An oil filter cutter. summit racing has one. I bought it and it works pretty good. You can cut the filter open without making metal shavings. Just don't cut your hand open also.
I asked recently about cutting filters open in the "Oil Filter: section. Folks use several methods, but one reply link was on a exhaust cutter - I had forgot that I had one I bought new years ago, just never used it.
The filter section has several filters cut open and the methods used to cut them.
I had concern also about metal particles cutting them with a hack saw, high speed air cut-off, or dremel.
To worry about it means r@r the engine and a tear down to inspect? Some metal could be normal. Probably the cam or cam chain is it a roller cam? Just the first guess.
LT1 is a roller. it would have to be from the cylinder walls and rings. i bet he raps it up every now and then. try a race oil man vr1 is cheap
+1
Thanks guys.
FWHP = flywheel horsepower
lol
I have been using Regular Pennzoil 5w30 but I recently bumped up to 10w40 to boost pressure a bit. Pressure has never been a major issue but my bearing clearances are a tad looser than OEM and many have suggested a bit higher viscosity oil.
I have been using K&N oil filters and they are cut open with a filter cutter so there is no chance of shavings.
Motor has a billet roller cam.
how do you drive it? are you seeing sustained high rpms or just redline shifts every now and then?
if its seeing a long time above 5 i would go 20/50
if your just hitting 7k getting on the highway i would go 15w40 rotella. it really sounds like rings and bore wear but if its stroked of has a crankscraper its a whole new ballgame
Originally Posted By: mechtech2
Stick shift? Maybe from the thrust bearing surfaces, whick is kinda normal.
Those wouldn't be magnetic however. The bearings are usually tri-metal.
The oil the OP chose is WAY UNDERSPEC for that engines specific output. Run a better oil. If running "on the cheap" you could run 4T superbike oil - that stuff is better antiwear than anything you get off the shelf - even VR-1 smog legal. Dont run any SL or SM oils unless they are REAL syn + have confirmed high % ester basestock.
