Originally Posted By: Pablo
Mike - ah I see you have Redline done. Amazingly little chat about this.
Did you give any more thought to the measuring technique? Just for reference, you say/write micrometer but you are using a caliper.
Anyway where are you in Washington?
The reason why i didn't bring the redline up is because its kinda a mute point... i ran out of bearing so i can't do a good comparative test.
Caliper/Vernier/Micrometer, in essence it's the same device. It can measure very small changes.
http://en.wikipedia.org/wiki/Micrometer_(device)
Seattle/Western Washington.
Originally Posted By: bruce381
to be at all even close to both repetable and accurate you must:
use same lot of bearings
same lot of bearing cup and change it or at least clean down
because previous tested oils aw additives will stick to the ruff surface so after 1 run it must be replaced tho not practicle so scuff it down to NEW each time with a file or stone.
best mesurement is to weight in mg the bearing ad report the wt loss.
Also oil/bearing/cup should be run in for 10 seconds or so with NO load just the wt of the handle on it then run test.
wt should be a static 10LB wt attached to handle NOT manually
pushed down.
do everything that same each test.
So to recap I would add the wt to the handle
clean cup down to bare clean smooth metal each time
run in no load for 10 seconds
I have doen this and get very repeatble numbers and IMHO valid for the work I was doing at the time
bruce
The eight oils i tested, i used the same bearings; they came out of the same ASTM certified box. I thought i had more in there (opps!). The bearing i used for redline i got out of an actual bearing race from an auto shop.
Did you watch the 3 hrs in 86 seconds video? I took 1 frame for every 100 and made a quick video. It shows my entire process non-stop. I sanded the big bearing down, it's like new then. Next time I'll use a stone because it would sure make life easier. Thanks for the Tip!
I don't have access to a triple beam balance, so i guess if i do this again I'll have to go buy one. Is a triple beam balance what i want? Once again thanks for the Tip!
The no load break-in did happen, i edited the video so it's no longer there. I guess i'll go back to the videos and record the break-in time and post it.
For the weight do you suggest that i cold start with the weight already on? It's not clear what your suggestion is because i didn't push the weight down. I'm not an actor and i did this in one shot by my self so if it does look like i pushed down, i didn't. I'm not trying to prove one oil over another, so for me to do that makes no sense. I'll post the amount of time it took for the weight to be added.
To all, thanks for the critiques! This will help to make future runs better. Keep the comments coming!
