Timing Cover Oops
CA
Resealed my timing cover today and realized after install that I forgot to add sealant to the circled area. 🤦🏻‍♂️
So, 3-4 more hours of teardown, cleaning and redo. Plus 4 days since some of the gaskets are one-time use.
How was your Friday? 😛
I'm glad this Friday is over. I'm glad this week is over, everything seemed to want to put up a fight this week, even something as simple as lug nuts. :rolleyes:
Oh well, we make it right and move on. Cheers. 🍻
Found time to get back to this car.
Notice how little RTV is on the mating surfaces. Most of it packs the “groove” and/or gets squeezed out. So, more RTV does not equate to a better seal.
Cleaning this stuff is real fun. This is just an in-progress picture.
Don’t worry about the particles, I will send the cover thru a parts washer after I am done.
IIRC the spec for Drei Bond is a 1 or 1.5mm bead.
Sounds about right for German cars. Their parts tend to be more finely machined so the needed gap fill is significantly less.
I was wondering about those spots & figured there was a reason.
I didn’t put enough RTV on two of the T-Joints last time and it started seeping after 25-30K.
Got the mating surfaces cleaned up. For access, it was easier to do the cleaning with the chain removed.
Now just waiting for the o-rings and gaskets before I can reassemble.
Looks like a Prius. I have done several head gasket jobs on those. My current daily driver 2010 Prius (commercial use) needed a head gasket at 515k. Now has 670k on it. No oil leaks knock on wood. Definitely nerve-wracking getting everything clean, the FIPG on the cover and then wrangling it in there without disturbing the FIPG.
I am curious. Did you run it before remembering that you missed that spot? I wonder if it would have even leaked. Those two machined surfaces pressed tight together right there at that bolt. Not like it's under pressure or anyting, just splash oil up there. All the critical oil pressure passages are o-ringed. I'm thinking some type of sealing washer underneath that flanged bolt head. Kinda like old Honda valve cover bolts if memory serves. Or just a small version of a drain plug gasket. Those hold oil and don't leak. Or... since it's your personal vehicle, just get it good and clean with brake parts cleaner and fill that entire cavity with FIPG (over the bolt). Just thinking out loud.
Of course this is a moot point now since you fixed it correctly. 👍
Reassembled it on Tuesday night. I didn’t forget the “spot” this time, but I accidentally smeared a hair of FIPG on the crank snout while wrestling the cover in place. Squeeze out around the entire perimeter looks pretty good so hopefully it will be fine.
Waited 36 hours for the fipg to cure before adding oil and coolant. So far, no puddles…yet.
