noodlerooney,
If one is changing his timing belt every 60,000 then every other timing belt seems reasonable for the water pump, but if one is using the Honda recommended mileage of 105,000 miles (for at least some models for the last 6 years), or the Toyota recommended mileage (at least for some models for at least the last 6 years too) then those water pumps are going to be in for a long time. 180,000 to 210,000 for a water pump seems like a long life for a water pump.
Trey needs to find the actual mileage/year recommendation from Honda on his timing belt. If it is 60,000 miles then I think you and KenW are reasonable with your every other timing belt recommendation for the water pumps, but if Honda is recommending a longer interval then the incremental cost of changing the water pump with each timing belt is probably the more reasonable, and prudent, course of action.
Trey needs to provide more info on his car so we can give considerd advice on his "apples" rather than advice that applies to the "oranges" that lurk in our garages.
Cheers.
[ November 24, 2004, 02:34 PM: Message edited by: BeltwayBandit ]
