Originally Posted By: unDummy
Short tripping is different than low mileage driven.
If you drive 2 mile trips 5-10x a day(soccer mom), then that's short tripping. This situation will typical beat the oil up quickly and is a candidate for sludge, varnish, consumption, moisture and fuel buildup.... I wouldn't blindly go more than 3 months OCI's with this vehicle.
If I take my convertible out for a 200 mile run, 3-5x a year, than that's low mileage driven. I can go a couple years on the oil in this garaged vehicle.
No one is trying to force you to buy oil or change it too often. But, I'll sell( @100% profit margin ) and install( @$150/hr ) a new engine, transmission... for you when its time.
You can use the used oil analysis w/tbn to 'help' determine the OCI. Its really simple.
Without the used oil analysis, you determine your margin of error with your oil choice and interval.
My "margin of error"... never replaced a component due to lubrication failure.
My neighbors/colleagues... there isn't a week when someone isn't having to repair an engine, steering pump, transmission, transfer case, rear-end, brake hydraulics....and there are only 200 of us in the building.
An engine is more of a waste of money than a few extra gallons of oil.
The lack of common sense with vehicle's maintenance is incredible.
Nicely said. I don't understand the obsession of extending OCI's past mfg recommendations in severe service or short hop driving. In fact I don't see the logic in extending it in normal service either unless you are really piling on the miles. Part of car ownership is maintaining the vehicle. When in doubt change it out, or get the oil tested and see just how far it can go. Following an oil companies sales hype or what a saleman tells you IMO is a mistake. Either follow the OM or use data obtained from your vehicle, not someone else's vehicle, or a used oil analysis report you read here. JMO
