Yes, at least the ones I have installed.Those kits come with everything, The idler pulley as well?
Gates may well make the OE belt but it zero in common with the one you buy at the parts store or online unless its from an actual (car brand not Gates) dealer. Ditto pulleys, idlers and tensioners. That is not to say you cant get a good deal but it takes educated shopping and research and even then it can be a crap shoot.I have a Ford Edge, it's time to replace the belts, as they are starting to get glazed over and squeal a little bit when cold, what brand do you recommend? I'm going to have the tensioner done at the same time? Which brand, at one time Gates was a good brand.. Motorcraft, Gates, Dayco or Continental.
I have noticed, Dayco and Gates has a Serpentine belt component kit..
I found Motorcraft belts on eBay, obviously I don't know how long they've been sitting in storage for or anything, would any of you all sweat buying them?
Thank you for reminding me about that.. I really appreciate that, my mind doesn't function the way it used to I'm really sorry.. I'm on a lot of medication because of my health.. I'm really glad you chimed in ..It is usually not a good idea to buy that stuff on eBay. They are full of fake/counterfeit parts. If ebay is a must, only buy from a reputable dealer.
Rock Auto is better.
I’ve had dayco squeak when brand new. Depends on the design. OEM, gates or continental I’ve never had a problem. Tensioner, definitely OEM or just replace the bearing if you can.I run Gates or Dayco and I have never had an issue.
OEM belts are going to be Gates, Dayco, or Continental anyway
Keep in mind Rock does a lot of drop shipping which is fine but they also buy a ton of stuff from businesses going or gone under and have no control over the origin of those parts.It is usually not a good idea to buy that stuff on eBay. They are full of fake/counterfeit parts. If ebay is a must, only buy from a reputable dealer.
