Ticking noise in cold weather - why?
It reaches 40 grade when the oil reaches 100* C after about 20 minutes or so of operation. A 5W40 is thicker at all temperatures than a 5W20 would be. Read what Gary Allan mentioned above for a better understanding.
Frank D
I looked at the Pennzoil website and the viscosity for Pennzoil Platinum 5w20 is 45.73 at 40C the 5w30 is 57.5 and the 5w50 is 106.
I changed from Rotella T Synthetic Oil 5w-40 & Pure One Purolator oil filter to Mobil 1 Synthetic 5w-20 & Mobil 1 over size M1-301 this element uses a synthetic fiber blend that can filter out very small particles also, like the Pure One
Maybe I didn't need to change the filter also, I used 5w-20 it has made a world of difference in the ticking noise.
2006 Dodge Grand Caravan 3.8L - it calls for 5w-20 I was using 5w-40 I will report back with some info soon as the weather gets single digits again maybe this has cured the ticking.
I think I was getting a dry start with the Puralator Pure One, when I took the filter off, I could shake the filter and hear a rattle inside.
I don't know if that means anything, but I do know the retaining spring was loose. I could send this to someone if they wanted to check into it.
Originally Posted By: rshaw125
Put the correct oil in it and a good filter. Mobil 1 , Pennzoil Platinum 5w20.See if this works .
I did exactly what you said and the problem has been corrected I used an MI -filter and Mobil 5w20 synthetic oil.
A BIG THANKS TO YOU AND EVERYONE ELSE
Originally Posted By: RedByrd
It has been my experience that, depending on the design of the filter, dry starts can happen if they are accidentally dropped or handled rough. Even if you didn't, you don't know what happened at the parts store or delivery truck.
When I shake this filter something rattles inside
