Originally Posted By: willix
I just had my TB off for a coolant leak repair that exposed the intake for the first time. I have never sprayed out this TB this is 105,000mi
[img:center]
http://i826.photobucket.com/albums/zz183/billytheshoe/100_1145.jpg?t=1283127879[/img]
inside the intake.
I'd clean that throttle body bore and plate real nice, but leave the intake alone. Either leave it alone, or take it off and clean it out perfectly. With all those convolutions, it won't help to clean it. But, you can do harm easily.
Concerning oil, it all depends on HOW you cleaned your TB. If you simply sprayed stuff down the pipe, your oil will have some added particulates and solvents in in afterwards.At least some.
Manual cleaning won't affect the oil. A manual cleaning is best, anyway.
This is why I use a catch can system. It attenuates or stops deposits like this from forming.
I am considering intake removal at some point
I removed the TBS /idle controller/MAF and hit it w/some Berryman's it all cleaned up well.
