A few questions about cleaning the throttle body of my Lancer, one regarding molybdenum.
I can find 2 versions of the workshop manual. The first does not mention molybdenum at all, and the other one mentions it and warns against removing it:
Here are my questions:
- http://faq.lancer-club.ru/download/...009-2012/2009/13/html/M113100100137900ENG.HTM
- http://faq.lancer-club.ru/download/...009-2012/2012/13/html/M113100100241300ENG.HTM
- Is moving the plate by hand safe? I don't see the manual's instructions warn against doing it, but at the same time I see posts in different forums mentioning that manually moving the plate will result in loss of calibration.
- Does my throttle have molybdenum? (From what I can see and understand the answer is yes.) If yes, which areas should I avoid cleaning? Should I avoid cleaning the edge, the perimeter of the plate? What about the plate's axle? I see it's black too. Is it covered with molybdenum?
- Is resetting the learned value necessary or is it possible to omit it with the ECU adapting without the reset?
