Thread locker
AP9
Chicago suburbs
Hello, sorry if this isn't the appropriate place to put this question, but I figured I'd ask it around here since I'm not finding a consensus elsewhere on the Internet.
Is blue thread locker sufficient for 1/4" NPT brass air fittings with air up to 125 PSI? Or should red be used for ths application?
Loctite will be fine but that's not really what it was made for... use teflon tape or pipe thread sealant paste.
Good luck getting it back apart.
I thought they were talking about me
I always keep Teflon tape back about 1 thread from the end of the fitting. That way a loose bit of Teflon tape cannot get into the air line and foul something downstream.
If you have to clean some old Teflon tape off of pipe threads, a small wire brush works nicely.
Thanks all for the advice. I had some blue stuff just lying around so I used that and it seems to be working ok.
