- Joined
- Dec 27, 2020
- Messages
- 310
GTL base stock vs say PAO or others?
Better Noack than what?Oils made from GTL usually have significantly better noak with good flash and pour performances.
The general consensus on this forum is to down play the importance of base oil, however, it must be taken into consideration that the base oil makes up 80% of the finished product.
Well, it's made with the same process (hydrocracking) that's why it's a Group III oil. The feedstock of course is different.Would love to learn more from the more knowledgeable residents here on GTL but from a amateur I would say it is more uniform base oil than hydrocracked crude. Called group III+… Reasonable VI to the base oil. That leaves room from a price point to put a better additive package to manufacture. It is all about what product you get for your money. Not PAO but a balance that gives you what you need for the US OCI schedule.
Is this info just about Shell GTL or GTL in general?
http://gasprocessingnews.com/featur...roduces-clean-base-oils-from-natural-gas.aspx
True, but also because it meets the VI, saturates and sulfur requirements of API Annex E. It’s about interchange of base stocks, not a descriptor of a finished product.Well, it's made with the same process (hydrocracking) that's why it's a Group III oil. The feedstock of course is different.
It might, but once again those aren’t requirements listed in Annex E for base stock interchange. You talk about people focusing on the wrong things on here yet you’re doing it with measurement properties that aren’t related to the Group designation. I’d counter that people focus too much on Noack, flash point and pour point which are relatively unimportant to performance in use.Oils made from GTL usually have significantly better noak with good flash and pour performances.
True, it could be Group II if the VI wasn't high enough (like Mobil's EHC bases).True, but also because it meets the VI, saturates and sulfur requirements of API Annex E. It’s about interchange of base stocks, not a descriptor of a finished product.
The original slate of them was:One limitation I’ve read about GTL base oils is that they naturally come out very thin - you can’t make thick GTL bases.
Therefore, without a lot of correction fluid, you are limited to lower-viscosity oils. All PP oils are very thin for their grade.
How is Noack unimportant with so many turbocharged engines prevalent now?It might, but once again those aren’t requirements listed in Annex E for base stock interchange. You talk about people focusing on the wrong things on here yet you’re doing it with measurement properties that aren’t related to the Group designation. I’d counter that people focus too much on Noack, flash point and pour point which are relatively unimportant to performance in use.
Where is it superior?My understanding is PAO is inherently superior to GTL, however the final finished product is what matters in terms of real world performance. Having said that, if you can purchase an oil from a mainstream manufacturer that happens to use primarily PAO as the base I say go for that.
https://www.machinerylubrication.com/Read/422/gas-to-liquids
I wonder then what kind of base oil formulation Shell Helix Ultra 10W-60 has for example.One limitation I’ve read about GTL base oils is that they naturally come out very thin - you can’t make thick GTL bases.
