Redhawk454
- Joined
- Dec 30, 2022
- Messages
- 388
Lifter issue (yes, we got a HEMI):
The lifter issue will never be solved or go away. I've beaten my head against the wall with this one until I replaced enough "Made in China" Timken bearings to realize that we're about 20 years past quality bearing steel.
Meet the latest casualty of bearing failure in my life:
I just replaced it with a brand new re-manufactured unit. The pinion bearing was gone.
The bearing steel today isn't as good as it was in the past because of mass manufacturing requirements. To put it bluntly, I don't think there has been a period in human history when mass consumption has been so rampant as it is today. Manufacturing hardened steel components for so much machinery that we consume on a daily basis is a monumental task. That is where the real problem is.
To make a long story short, two things destroy bearings and lifters today:
1. Dirt - contamination.
2. Humidity - emulsified motor oil, or water in the motor oil - from short tripping the vehicle.
No downsides, only upsides. You will get better protection. No warranty issues either, as motor oils like Mobil 1 ESP 5w30 are API SP licensed.
What caused the 7.3 lifter failures? Seen some reports on other forums about the electric oil pump only pumping 7-8 psi at idle and Ford having a TSB about re flashing to bad metallurgy on certain lifters.
